The Reaper said:it works fine
im going 1JZ now and will be swapping to a 2JZ later on and will be running on 1JZ harness and either 1JZ ECU or AEM
tissimo said:all plugs are the same.. even the isc.. i checked the pinning, and its the same.. it plugged right in..
IMO just get a 1jz -> 2jz jumper harness for aem.. or just get a powerfc or something of the like.. no need to get a 2jz harness ($$) then then spend hte time pinning it out for the mk3 body..
becauseican said:Heres what I am thinking. I currently have a 1jz with a Mines ecu/ emanage and 680cc injectors. Now if I swap in a 2jz motor and run it with just the Mines ecu. I figure with the extra displacement, it would run lean, but by using the larger 680cc injectors it should be close to even itself out without much correction. I am not aking about with a standalone, i mean stock type ecu.
