any advantages to adjusting CPS for more power?
grimreaper
2,180
Dallas
only to adjust timing. Stock ecu actually provides a healthy amount of timing under load and at wot already(depending on air flow). Set it to 10* and leave it alone.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
Though if you are using the lex afm or are pulling fuel to tune out fuel cut, pulling a couple degrees timing wouldn't be a bad idea as timing us calculated from load witch is calculated from airflow. Less airflow appears as less load meaning more timing.
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
well, i have the lexus afm, walbro, and 550's so i just curious if that would help at all. so would adjustable cam gears make a difference?
-t3d
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
As poodles said gains would mostlikely be null. But if your tuning for max fuel cut pulling lots of fuel it might not hurt to be on the safe side and pull a degree or two.
suprajztwenty
369
corinth tx
so lets say i was planning on making a cross country trip with almost no boosting, would advancing a couple degrees help with mileage or atleast with the low end power band, 1500-3k?
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
Mostlikely not as the tccs actively seeks best timing based on feedback from the knock sensors. Don't forget the CPS also is timing for injection aswell.
