Anti police Smoke screen
ToyoHabu
261
Huntsville, Alabama, United States
Or is my supra an anti mosquito sprayer. Either way may car smokes and I listen to what the surgeon general says and I want to quit. SO I need to determine where and how the oil is getting sucked into the cylinders to be burned. It does not smoke All the time but it will make great big cloud when I apply thottle and I had been coasting prior. How do you tell if its is valve stem seals or the turbo seals. ? Cause no matter how fast, quick and mean you sound, if you smoke its Embarrasing :nono:
souprat
fairfax VA
compression test? cylender leakdown test?if its the turbo you can check the shaft play, or take off the dp and look for carbon to be built up on the turbine.i thought i heard that leaky valve stem seals will smoke right when you start up cuz the oil leaks down when the engine is off. well thats a start, hope you can kick the habit.
