Anti Lock (see pic)
bonus12
Backroads Driver
Jul 15, 2006
143
CA
my anti lock light is lit up, and i can't figure out why. i checked the fuses, but found nothing. any help? my search didnt come up with anything...
THANKS
bonus12
Backroads Driver
Jul 15, 2006
143
CA
how do i run the ABS diagnostics?
where is it plugged in...what does it look like?
thanks very much.
Finnon
701
South Shields, Tyne & Wear ENGLAND
reading the diag codes is easy as mate, just follow the manual. if you change any parts tho read my recent thread as i had some problems with mine reading weird codes due to parts from a later car going onto an early model abs computer
Racefiend
OH, YEAAHH!
Apr 6, 2005
106
Bay Area, CA
Are the lights for the tems lit up at all? I had a problem shortly before I sold it where the abs light was on and the tems didn't work (all the tems lights were off). I traced the problem to a 15A fuse (can't recall which one off the top of my head) in the kickpanel was not making contact, as it was in there pretty loose. I bent the receptacle pins so they would make contact and everything was back to normal. It's possible it could have loosened up again.
