Anti-lock mani....
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
well, im removing some of the parts from my engine bay to clean them and cover them in high-temp paint to make them look nicer. when removing the anti-lock mani, should i expect any leakage or can i just go ahead and unscrew everything safely and just put it back in when im finished (like an hour later after cleaning up that area)?
thanks in advance.
gixxer750
2jzget comingsoon!
Mississippi
yes, its going to leak fluid everywhere....when you are done you will need to refill and bleed your braking system. It probably needed flushed and refilled anyhow though :)
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
removed it on sunday. amusingly, not that much fluid came out. just a few steady drops that i managed to stop by putting clean tissues in the holes. although, when i went to get a soda, i came back and some had dropped out and fell on the chassis. good thing i bought Gojo and cleaned it up in 5 minutes. looks brand new now :D
