another hg...?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
got a worrisome head gasket. so far i'm not showing symptoms like low coolant, a mobil 1 milkshake or rapid temp spikes.
however, i do get some white smoke on startup. looks almost like condensation, though. how white is the white smoke, is it like a freaking cloud coming out? can someone describe how sweet it would smell?
and as for a waterfall sound behind the dash, i get it a lot during intermittent use of the heater (happens when the heater is off). is this just air in the heater core or is it the dreaded waterfall?
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
It wasn't really sweet whe nI smelled it, not sweet in the sense anwyay. It's not cgona smell like candy is what I mean :p It spells like something wierd, you'll know it's not oil, and not gas, so it just this "other" thing. Is it just on startup?
eric
Clip
Oct 16, 2005
2,738
9
Virginia
you probably wouldnt, but ive put almost 10k miles on this since ive gotten it and its still fine. besides, if i blow it itll be an excuse to go turbo!
as for coolant leaks, JAV, none whatsoever. all tanks are staying full.
and as far as i know, the smoke is only on startup (condensation, probably) but i've never been driving behind myself so i couldnt tell you fo sho.
