Another HG ?
Wendigo
Ericsplosion
Jul 25, 2005
331
New Paltz NY
Simple Stock or HKS? I have both, not convinced the machining was good enough, not planning on hitting 350 hp anytime soon, but not sure about durability of MR. OEM. Looked around but not sure on the answer for this. Thanks
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
As long as you aren't concerned with the possiblity of tearing it apart again, for lower power goals I'd suggest the OEM.
On the other hand, I put in my HKS on a rougher surface than suggested by using the Permetex brake quiet spray on the gasket, it's been fine so far.
Seems to be pretty much a hit and miss situation, picking one over the other.
shaeff
Kurt is FTMFW x2!!!!
11
Around
i am also having much luck with the permatex brake quiet on my completely un-prepped block. (no, i dont recommend doing that). however, my head was machined very well, i used a razor blade on the block, made it super clean, and relatively shiny.
coated my cometic MHG with permatex, slapped that shizzle together (cut off the rivet) boosting 15psi no problems. :)
-shaeff
