Well guys I got my valve cover seals fixed and it was all going very well. Now 1100 miles later, I've encountered another problem.
I went to work one night and when I finished my shift I went outside and tried starting my Supra but it didn't wanna start up. I took off the manifold and checked all the spark plugs and there is a little bit of coolant in there but I found out there was a hose dripping coolant into them. So I got them cleaned out and the coolant line clamped better. It still didn't wanna run though.
Basically when I start it up, it'll shoot up to 2000 rpm's and drop. Then back up to about 1,500 rpm's then drop lower then the first time, then it goes back up to roughly 1000 rpm's and then it'll drop to about 250 rpms or lower then it'll sputter and die.
If I rev the engine to 4000rpms as soon as I start it, then it'll stay going as long as I keep it at 4000+rpm's. I did that for about a minute then let off the gas and it ran just fine as if nothing was wrong. I took it home and started it up again about an hour later and it was fine. Then an hour after that I tried again and it did the same thing while it was running. It started sputtering and it died again. The spark plugs and all that are still clean.
Does anyone have any idea of what's going on. It's been a few days since this happened cos my computer isn't getting a wireless signal so I couldn't post it sooner. Anyways if I don't respond very quickly then that's the reason why.
Thanks
Thanks
