I am about to swap my 92 supra to an r154 trans...I was not planning on changing the rear diff...Is the 5spd diff the same as the auto? Also someone told me that there is a spacer (i believe) behind the flex plate, that I need to remove before I put in the flywheel is this true? Is my gearing/speedo going to be off? I know these might have been answered before but im looking for some reassurance, that my car will work properly If I do the swap and dont change the ECU or diff.
Thanks
Thanks
