Ok all, Im trying to find the Correct Size for the Stock Oil Feed line so I can use an AN Fitting in its place. This is the Size that screws into the Block.
I need the Sizes and what Size AN would be recommended.
Block fitting for the Oil Feed line
Fuel filter hole and what size AN to use
fuel Pressure regulator hole fitting to what size AN to use
Thanks
Robert
Thanks
Robert
