Neil said:Kinda curious, will I have to do any conversions swapping my 7m with a 7m off the JDM?
Thanks
That's not true, I just switched the two out like mentioned, mine is working perfect.Fuzz420 said:yes you will need your oil pan, and intake manifold.
The jdm ge's are from cressida as they didnt put the ge in supras in japan.The rest is plug n "pray"
GotToyota? said:That's not true, I just switched the two out like mentioned, mine is working perfect.
-Matt
Neil said:Thanks, I had some unreliable sources telling me other wise.. Might have to go knock some teeth out
Yeah I did as well. I'm an 89.Fuzz420 said:interesting, i had to swtich oil pans, what year are u again, im a 90
supramacist said:speaking of oil pans...., mine is leaking on my 91 supra. Can I just replace the seal and be good to go, or do I need an entire oil pan and the seals??? thanks.
supra90turbo said:7MGE in Japan only came in the Cressida, which is front sump.
Therefore, if any of you got a "JDM" 7MGE that is rear sump, then it's not JDM!
supra90turbo said:Also, to clarify, there is no oil pan "seal" or "gasket". There is simply RTV. FIPG from Toyota works best.
