It seems that with this car it has been one thing after another. I love it, but i'm getting aggrivated and need some help with this problem.
I was about a mile from work cruising at a steady 14% throttle when i see my tach randomly drop 700 rpms (i mean 1/4 second quick, stock flywheel). This problem is common and will happen once randomly about every third time i drive the car. The car will keep driving fine like nothing happened. Just a little jolt and back to normal. Anyways, this time was different. The car does it once, i think its gone, but no. The car jolts and the tach bounces again. and again. I'm headed downhill and just pray for the car ahead of me to speed up. so i can possibly make it back up the next hill. no such luck. I decide to keep going considering there is nowhere at all to park it. I give it some more throttle and the car jolts and backfires up the hill. The problem comes and goes but is getting increasingly worse. I arrive at my destination. I check codes (i get 14). I jiggle the CPS wire. No worky. i check coils, plugs. Everything accesable. I check my maft wires and for vacume leaks. none. I re-set my ecu. No change. The car idles fine, i guess perfect? Its hard to judge how well it idles when your looking for something to be wrong. It pulls 21 vac.
what i think...
I'm gonna go check it out tomorrow with some tools. It sounds eletrical. My wiring harness is like a rats nest with a zeitronix, SAFC, and MAFT. I think my RPM wire could possibly be grounding out. Now dont flame on me because i dont know what the effects of this would be. It seems to make a little sence since the ECU reads RPM and the tach was going crazy. This does not explain ignition, unless the igniton map (or whatever) is screwed up because its confused by the RPM
what i think...
