Aluminum driveshaft noise
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
My aluminum driveshaft seems to make a hollow clunking noise when engaged or disengaged by the drivetrain (when stepping on the gas and letting off). Is this common? I'm tempted to zip-tie a couple of small pieces of dynamat sound deadening material on it to at least get rid of the hollow ringing sound when it clunks.(keeping balance in mind)
gaboonviper85
3,236
Northeast Philly
sounds like the bolts that hold it to the diff are loose....ask me how I know LOL
If you can take a pick of the drive shaft I'm sure we could id it...
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Exactly what I was thinking. Make sure they are tight. I've had the exact same problem with the same symptoms with my factory driveshaft.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
my steel driveshaft clunks, but im almost positive thats due to the ancient diff i have, and the subframe bein a little tweaked...
and god damn your car looks good!
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
My steel 1pc does that. I don't have any more play in the diff than you'd expect. The long hollow tube doesn't help quiet it either. If everything's tight your only real option is rebuilding the diff and making it nice and tight (especially on the input side).
EDIT: Oh. but mine doesn't "ring" at all.. just a small clunk.
Asterix
Lurker of Power
Vienna, VA
Mine did that because the tranny output bearing was shot and had a lot of play in it.
Climb under there and see what's loose.
Asterix
prsrcokr
Motörhead
Apr 3, 2005
349
Richmond
Do you know what diff you're using? My Torsens have a slight clunk noticed when engaging. Noticed it while rebuilding as well but seems to be part of the design vs. a cluth type.
