Ok...here's what I did:
1) Alternator went bad...showed 11.5 volts on the dash meter; plus it was very hot to the touch
2) Replaced battery w/ brand new one 850 amp
I bought a MR2 alternator '91 (w/ powersteering)...thought I'd upgrade to a 100 amp one since the old alternator was bad. During the install, all 3 wires on the connector were very brittle and two broke off even with the plug. I bought another plug and spliced the wires...the splices are good. I used my old alternator pulley to match the belt...fit perfectly. The MR2 alternator fit fine...a little tight, but no real issues. Belt is nice and tight too
Got everything back together and now the dash battery light and brake light come on very dim. The volt meter shows 13-14 volts depending on rpm. Also, the headlights and interior lights are dimmer at idle...over 1000 rpm, lights are normal. The battery and brake light stay on regardless of rpm.
I had the new MR2 alternator tested before I left the parts store. I also had it tested on the car...that's how I found out my previous 3 year old battery was going bad. The new alternator tested within spec on both the bench and on car tester.
I've checked wiring...I can't figure this one out. Why would my battery & brake light come on like this? I know it usually means the alternator is going bad, but the volts read w/in spec. Any ideas?
Thanks
Thanks
