I have some more noob questions for you kind folks
I am going to put in an electric fan and scrap the hydraulic system from the 1JZ fan and water pump. Will a 2JZ water pump fit the 1JZ? Will it work with the serpentine belt system?
Other question is will a 2JZ 90 amp alternator fit the 1JZ? If so, I should be able to use the 1JZ alternator as a core... :eek3dance
