Alright guys Codes 24 , and 41,
amped12345
46
League City, Texas, United States
So my cars been operating fine after rebuild but as of recently it started to give me a check engine light when i let off the gas quickly , and the rpm drops very quickly then it climbs back up to where it was and the check engine light disappears instantly , and sometimes it stalls. so i decided to check for codes and 41, and 24 popped up , and from reading a bit . i hear that means there is a short on the tps and the air temp sensor . only thing i can think of is when a heater hose busted water hit over by the AFM connection and air temps sensor , but didnt do any damage from what i looked at i pealed back some of the insulation wires look fine. no gaps openings or anything so my best bet was to unplug the battery and anything that is in relation with those codes. and take it from there. Any Suggestions guys ?
24 is air temp sensor or it's circuit.
41 throttle position sensor or it's circuit.
If you clear the codes they will prolly come back if it's stalling. If you have a buddy could try swapping a good afm in and see if the problem goes away.
