i now have spark, when i spray starting fluid in the intake, it will start for a second.... now i need some help. i thought i had fuel. when i took off the bolt on top of the intake, (the one that has the fuel line) it would squirt gas. so i have fuel, but how can i test if the injectors are opening and opening at the right time? what should the resistance be? what should the voltage be going TO the fuel injectors? is there a way to diagnos it thru thr diag port? thanks.....
