I finally got my whole car together and will be needing alignment in the next week or so, but I need some input.
First of all heres my suspension setup:
Tein Flex coilovers all around
FRONT:
No front sway bar
Front Ebay strut tower bar
Stock suspension bars and bushings
REAR:
Lipp traction arms with poly bushings
A1 camber arms
A1 toe arms
Unobtainium nylon bushings in the Upper A-arm and knuckle
I plan on using this as a weekend fun car with occasional trips to the local 1/4 mile strip. I drive on 245/275 street tires on 17" rims on the streets and Rx-7 rims with MT Drag radials on the track for the rear.
What kind of alignment settings would you recommend?
From what I heard I should go with 0 toe and 0 camber in the rear for traction. What about front?
FRONT:
No front sway bar
REAR:
A1 camber arms
A1 toe arms
