Alan's project car
Alan
82
Gulfport, Mississippi, United States
Here is the project car the day after I bought it. I got the car in Modesto Ca. not running. I will be posting pic's of the project car as I go along.
Alan
82
Here I started som cosmetic surgery and replaced the 86.5 tail lights with the 90 tail lights that were supposed to be in it. Then I used the blue hood off of the donor car because the old one had a crease the width of the hood and the under frame had seperated. The rear glass was leaking so had to pull it to fix it and found about 1/2" of glue placed in there and some of the clips were broke, so I fixed it with some of the clips off of the donor car.
Alan
82
Well here is some updated pic's of the car I had to replace the head gasket and found alot of the original parts were reused so a simple head gasket replacement turned into alot more work. I also did a little dressing up of the motor while I was puting it back together.
