Airbag light is on.
Oct 11, 2005
3,819
20
Thousand Oaks, CA
In order to reset the air bag light I made a little gizmo to switch between 12V and ground with a switch. If you read the TSRM, you will understand what I am talking about.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
A switch or a little frustration and a well timed hand with two wires, haha
Sent from my ADR6400L using Tapatalk 2
ifyouaint1sturlast
Banned Scammer - I'm whitemike.
Jun 14, 2011
480
Fort Myers/Cape Coral - Florida
Spanish Surprise;1845247 said:
I called the dealer and they're charging me $49. Done.
Why pay $49 for somebody to do something so simple?
Is it necessary for the 12v? From what I understand in the TSRM it just needs to connect to ground..
I was considering just connecting two momentary switches (TC>GND, AB>GND) and holding one in each hand.
Oct 11, 2005
3,819
20
Thousand Oaks, CA
You are correct, alternate grounds between Tc and Ab. I used a SPDT switch, with ground on the common and Ab and Tc on the two legs. Throwing the switch every second for 5 cycles clears code 41.
