aiight guys.... need some help real quick :)
boosted1jz
in reconstruction
May 9, 2005
167
alpharetta ga
i have seen it b4 but cant remember 4 the life of me..... what should the fuel pressure be at idle??? i have a AFPR i just wanna know what the pressure should be set at for idle???
also what air/fuel ratio should i be running between???
thanx
chris
jbsupra89t
Achieving Balance...
NJ
I run ~39psi base, and like (personally) between 10.5-11.5 TOPS on the street. Call me conservative I guess.
-J
jza71
HELL
MN, USA
www.geocities.com
I ran mine @32 psi on daily drivin and low boost, gas milage are really good. A full tank of gas I was able to travel about 400+ miles(highway). When racing I had it set @40-45 psi and 3 gallons of racing fuel lasted about 10 trips down the 1/4 mile.
by the way she's on 550cc:biglaugh:
spipedong
Level 2 Rythym Rogue
Apr 2, 2005
404
Eugene, OR
-J
Old thread, but 10.5-11.5 psi fuel pressure right?
I'm having some over rich problems on the 1JZ. My AFPR came set to a little over 40 psi at idle and it seems like thats probably too much.
