Ah Sh%t....no spark
gixxer750
2jzget comingsoon!
Mississippi
well after changing my whole engine setup, I tried to start, and I've got no spark.
Brand new harness, everything is plugged in. New coil pack ground. Good Block and chassis grounds
Tach doesn't move when starting. CPS is working properly. Tried three ignitors, and two different ECU's. IGN fuse is not blown.
Any ideas?
Oh yeah, coil packs are fine.
mattjk
Permanent Ban
May 18, 2006
1,973
Huntington Beach
try a different ecu if you think you have everything else wired right.
Is your ignitor grounded?
The coil pack ground is not really a ground, it's a drain wire. At least that's what it looks like to me.
gixxer750
2jzget comingsoon!
Mississippi
well I guess I'll check that in the morning.
Its just been hard to figure out, because I've changed so much. turbos, done alternate routing for the harness, battery relocation, Relocated all engine bay electronics, FFIM....and so on.
gixxer750
2jzget comingsoon!
Mississippi
Hal....you asshole. I told u that on the phone earlier.
Turned out there is a relay and the injector resistor that share the same plug. The way my engine bay is set up, the two are very close together. I accidentally plugged them in wrong.
