PorterzSupra said:
Why wouldent the aftermarket companys take advantage of watercooling? I guess it must not be that great... Anyway where do the 2 threaded holes goto on the external wastegate??
Buddy, I am not sure your on the same page as we are here.
The external wastegate does not connect to the turbo in any way. Those TWO ports ( one smaller than the other ) are oil ports.
Judging by your previous posts, it seems you have a T4 without oil jackets right?
Ok, the SMALLER port is the oil FEED ( oil goes in from the block here) and the larger port is the oil RETURN ( oil going back INTO the block).
The reason most companies do not put coolant jackets in the turbo's is that it takes up TOO MUCH space inside the housing...that space is utilized for oil...the turbo's are built to a better level of performance where they can withstand higher temperatures better than the stock turbo's.
And if you think about it, that coolant coming out of our stock turbos is INSANELY hot......and its being fed right back into the system...
I dont know about you, but commen sense says hot coolent no good!
Hope this helps some. If you have any questions please ask! If you do not know how to ask the questions...well ask anyways!
-Jonathan
