aftermarket inner tie rods for mk3??
drod23
60
Santa Paula, California
are there any aftermarket inner tie rods for mk3's?
or do inner tie rods from other cars work?
my mk3 tie rods ran out of threads,and need more so my alignment is within specs
(my tie rods are maxed out due to installing inner tie rod spacers)
kanji1jz
kanji
Jan 16, 2008
103
tampa fl
You could try installing more threads via tap and die set and cut off the end of the inner tie rod in order to get more out of it. How far out is it?
Shifty
20
Brisbane
No help to you, but I found a site the other day with a fairly extensive list of aftermarket adjustable suspension bits for the MkIII and just went looking but can't find the link. So, at least you know some stuff is out there still!
