i want to instal a boost gauge because im running around 12PSI. i just want to make sure i wont overboost and hit fuel cut. What vacumm line do i use to install it? if anyone could send pictures that would be fantastic
Sil;1081552 said:There's a nipple on the back of the intake manifold that goes to your factory boost sensor, thats where I tee'd mine in.
Sil;1081748 said:I ran mine across the top of the engine bay and into where the ECU and harness meet, then I just ran the line behind my dash as I saw fit.
americanjebus;1082358 said:I'm automatic, theres a nice 1'' rubber boot i cut an X into right where the clutch master cylinder is supposed to be.Goes right behind the gauge cluster.
mischief7m;1082535 said:wow, thats perfect,
i went for the strait route, i know it probably doesnt make a difference, but my thinking was the shorter and less bends in the hose, the better.
