When I take off again, after engine braking to a stop, I have smoke (blue or grey, hard to tell) when I take off again.
No smoke on start-up – not valve seal/guides
No coolant loss, over heating – no signs of BHG
Swapped out turbo – No excessive oil in intake path path (not turbo oil seals, right?). Heavy carbon built up in exhaust side and tail pipe.
Going through a quart and half oil a week
Getting 18mpg city
At idle, engine is running lean, ECU having to add max fuel - VF=5V (wouldn’t have to do this if leaky injectors, right?)
At WOT, A/F=9.7:1
Boost to 10psi fine, no vacuum leaks
That’s all the info I can think of right now. Let me know what other information would help diagnose.
Thanks.
edit: I didn't mean my engine is breaking,
I meant that I was braking to a stop using the engine :crazy1:
Getting 18mpg city
At WOT, A/F=9.7:1
Thanks.
