AFR's go off the chart lean when I lift...
fstlane88
Single time!!
South FL
I'm using a PLX M-300 wideband and have been noticing lately that when I lift, unless I slowly lift off the gas, like anything quick, especially after I've been in boost, usually only 5-6lbs, it just reads LEAN. It will then comes down back to where it normally is, which is rich b/c the car is untuned. Note this happens in the time span of about a second. As I go into boost it will start to read richer until it's off the charts rich, but I would expect it to read rich when I lift, or am I missing something?
~Bryan
Tim
regular member
Oct 16, 2006
272
CA
Yah man, my car does the same thing. I am using Zeitronix, and I was tripping out when I noticed my car did that the first time. My AFR's went very lean when I lifted!
fstlane88
Single time!!
South FL
Ok cool, just wanted to make sure it's was normal. Was worried it had something to do with the tune, or lack there of.
