AFPR question
1wickedA70
332
Queens
planning on upping the boost soon on my smokin twins :biglaugh:..before i do it im gonna install a fuel pressure regulator...juss would like to knw wut pressure the regulator should be at when uppin the boost from the 10psi i have now, to 15-18 psi i plan to run...i also have a walbro pump
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
When I ran 22psi on stock twins, I had stock fpr and stock pressure and was still 10:1...so I don't suggest you touch your setup.
When I installed my walbro and mkiv 550s I had to turn DOWN fp so I wouldn't drown out my fuel.
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
1wickedA70;1352959 said:
really? did u get fuel cut?...the reason i wanted to turn it up wuz because of fuel cut
Sorry, I wish I could help you more, but I have a Blitz ecu, so I have all of the 'cuts' deleted already.
supra1008
1,179
Philadelphia
1wickedA70;1353477 said:
anyone run 18 psi on a stock FPR...with a stock ecu, and injectors?
I'm pretty sure you can run 18psi on your stock setup. Instead of getting an FPR you should be getting an upgraded ECU or FCD or something. You should be fine. I have run 16psi and I was still at 10:1
1wickedA70
332
Queens
na dont wanna waste my time wit an upgraded ecu cuz im goin standalone soon....juss wanna have sum fun wit stock twins before i go single since there smokin...anyone else wanna chime in on this?...who else has run a stock FPR with the boost set at 18psi....i dont wanna hear about an FCD cuz fuel cut is there for a reason
