AFPR/FPD Bypass fitting question
Justin
Speakers?
Spokane, Wa
I'm about to put in my new fuel pressure regulator and fuel pulsation dampener bypass... It has those blue fittings on it. Do i need any type of gasket/tape/etc. for those fittings or do I just tighten them down and go?
dbsupra90
toonar
indiucky
the fittings should have a crush washer built on it. but if not you will need to use the stock ones. you dont ever need any type of tape to seal it. AN to AN fitting will seal by design. and AN to to a tapped hole will need the crush washer.
Justin
Speakers?
Spokane, Wa
Thanks guys.
Can the crush washer be re-used, or should I pull it off (assuming its there) and just reuse the copper o ring on there right now? Its pretty new (the copper one)
