i'm curious on the affects of this. i have never heard of this, but some gentlemen were commenting on that with my setup. i have the lexus AFM and the greddy rs BOV. so, some input would be very helpful. thanks!
-t3d
-t3d
I used to have occasional backfires when driving without a cat. I now keep it in, and don't notice any backfires. I was worried about the ceramic and checked it, and it was 100% fine after several months of driving. (Magnaflow brand cat)jdub;1291164 said:LOL...true statement...I get a few muffler pops now and then.
Hasn't seemed to hurt the CAT so far
the t3d;1291510 said:lol gottcha! does greddy make an recirculation kit for the RS?
-t3d
the t3d;1291513 said:nevermind! found them. TitanMotorsports.com has them for dirt cheap. this is going to sound gay, but because the BOV is recirculated, does the BOV sound get eliminated?
-t3d
jdub;1291339 said:Brad - it's the VTV that controls the return to TB closed...pinch the vac line after running at 2500 RPM and release to idle. It should high idle for 1 sec, then go normal after you open the vac line.
You could try a new VTV...or use a shorter, smaller ID vac line between the dashpot and VTV. No promises this will work, but you could put 2 VTV's in series on the vac line. The correct solution is to recirculate the BOV
