AFM upgrade
hammerhead
125
Belize
When doing the Lexus afm upgrade, do i need to get the electronics from the upgraded afm if the electronics on the stock one is good? Or does the stock electronics work with the upgraded afm. Thanks.
jdub
Feb 10, 2006
10,730
Valley of the Sun
The stock electronics will work fine with the Lex AFM...DO NOT use carb cleaner on the sensor that goes inside the AFM to clean it. ;)
Boss302
249
Mobile, Al
with this upgrade whats this i hear about at like past 15lbs there's not enough vacuum and the engine could run lean while not boosting or something like that.
MKIIINA
Destroyer of Turbos
Plano, TX
what? mine was fine at all times under vaccum and boost conditions....
lagged
1991 1JZ
new rochelle
:cry:
what shaeff said.
Boss302
249
Mobile, Al
thank you for setting me straight again it's just on one of these threads and a few others i've seen like on mkiiitech.com they said it cost them a motor cause of vacuum problems.
shaeff
Kurt is FTMFW x2!!!!
10
Around
the lex afm won't cause you any vacuum problems. if you don't add fuel to the mix with the LEX afm, then there's the potential hazzard of running lean. when doing air upgrades, make sure you have enough fuel to counteract it.
-shaeff
supraguy31
626
Pembroke, NC
I hope you are running Bigger Injectors with the AFM Upgrade. I didnt have any Problems at all and I was at the time running 17 psi all day
Robert
jdub
Feb 10, 2006
10,730
Valley of the Sun
A Lex AFM is about 25% larger than stock...550 injectors are 25% larger than stock. They basically balance each other out.
Fuel cut gets raised by allowing more un-metered air through the AFM...the ability to monitor air/fuel ratio with a wideband O2 is good insurance against inadvertly leaning the motor out and cooking it (that's the danger of using stock 440 injectors). This goes hand-in-hand with a fuel turner like the Apexi SAFC
A high pressure fuel pump and adjustable FPR are a very good idea too :naughty:
89mkthree
supies ignore irish luck!
Apr 12, 2005
138
near chi town
just so im really clear on all this before i do this setup. the lexus afm, 550cc inj, adjustable FPR, and 255LPH pump will do the trick but for safety i should get a wideband O2 and a SAFC to go with it. i could do it without those at first and add them later withou being in too much danger. am i correct on this?
jdub
Feb 10, 2006
10,730
Valley of the Sun
In my book, the Lex, 550's and 255 Walbro are required items for this mod. The adjustable APR helps with idle and provides min "tuning" ability...i.e. if you're lean, you can add some fuel pressure. The wideband is the only way you will be able to accurately tell what's going on with the motor...lean or rich under normal run and boost. The SAFC is how you will get the real power out of this set-up.
I have all of the above, except the SAFC...I'm going with an AEM stand alone and it will make the Lex moot. You could also go with a Maft Pro; it does not need an AFM at all, but you have to buy a couple of sensors...it also has the ability to control boost as well as fuel. Do a search on it for more info...personally, I think the Maft Pro is a lot of bang for the buck and no more AFM to boot!
