afm resistance
taka21
363
washington dc
im attempting to test an afm that i recently bought and i cant find the ohm readings that im supposed to check it against
does anyone know this information
please help
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
My bad. I'm going by an 87 TSRM which is all I have. Page FI 78, Air Flow Meter (7MGTE).
Unsure about newer manuals but they aren't in the online one. Wouldn't be only thing Toyota deleted from later books. The detailed AC compressor rebuild for example. Anyway:
Ks > E1: infinity
E1 > Ks: 5-10k
Vc > E1: 10-15k
E1 > Vc: 5-10k
THA - E2: As stated in other manuals.
">" refers to the direction of current flow when using the meter. They're obviously checking device junctions. Think diode testing.
Edit: see post below...
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
OK, I think I know why those specs aren't in newer manuals. They're wrong. In all my years of dickin' around with these cars I never resistance tested the Karman pins because it's just easier to dynamically test the AFM on the car or bench. So I decided to measure a known good one I still have lying around. I would use these values instead:
Resistance test:
Ks > E1: infinity
E1 > Ks: 4.1 meg
Vc > E1: 157k
E1 > Vc: 157k
Diode test:
Ks > E1: 2.490 volts
E1 > Ks: .700 volts
Vc > E1: 2.490 volts
E1 > Vc: .579 volts
Imo it's still much better to test it on the car...
