Hey,
Recently, my car suddenly developed a horrible idle and inability to rev. My first thought was the AFM and after checking the codes and getting 24 and 31 I assumed I was correct.
I then got another working AFM and the same exact thing happened.
I've tested continuity between either ends on the wiring harness and all 5 wires going between the AFM and ECU have continuity.
Since code 24 and 31 and seperate systems, it could have also been a bad positive or ground. I checked at the AFM end on the wiring harness with the key in the "on" position and I got 5 volts which is what it should be.
I also have a ground strap on the AFM.
I guess my next step is to get another working ECU.
If there is anything anyone could suggest or add, I'd appreciate it.
Thanks,
Alex
Thanks,
Alex
