AFM Orientation
Aspec
Supra uber alles
Dec 22, 2005
261
Surprise, AZ
Does the air flow meter's orientation (or sexual preference for that matter) make a difference. In other words does it matter whether it is horizontal or vertical? Or if it stays horizontal does it matter how it's clocked (sensor on top, side or bottom)? And if it does matter what would the tolerences be (no more than 45 deg from vertical for example)? Just curious how finicky it could get. :icon_bigg
Thanks for your input.
_
Nope, as long as it's not backwards it will be fine...
Though... if the sensor box is on the bottom, and oil residue that made get in there will get into the box easier.
Aspec
Supra uber alles
Dec 22, 2005
261
Surprise, AZ
Poodles;1094042 said:
well, you can use MAFT to use a GM style AFM in blow through mode... but it's not the ideal setup
Not ideal in blow through mode after the IC, or not the ideal alternative to replace the AFM when used in it's oe position?
_
