I just installed my new afc neo and I set all the settings and then started the car and it would idle fine but as soon as i gave it any gas it would bog and almost die. It had the same symptoms as if my afm was unplugged. So I reconnected the signal wire and the car worked fine. Has anyone had this problem or any idea what is wrong? I set the sensor type as karman like the book instructed.
