hey guys, i juss finished wiring up my neo to my 1j, all im waiting for is my wideband to tune. it seems as if everything is working except the throttle. when i go to set it, it doesnt read any volts. and it keeps saying NG (no good) when i try to set it when the arrow is pointed up. when i set it when the arrow is pointed down it sets when i click ok, no matter if i step on the throttle or not, it always says succesful.
when the arrow is pointed down it told me to set it once with the throttle closed and once with it fully open. when it tells me to fully open it, it says "successful" but reads no volts then when i start it the throttle reads at 100 percent. idk whyy? i tryed it again setting it with the arrow pointed down but this time i didnt press it at all and it still said sucessful! only this time i start it and it says throttle position 0 percent.
but when i go to the throttle setting with the arrow up no matter what i do it says "NG" and still reads no volts no matter how i press the gas pedal. help me i went over the wiring a million times and everything is in the right place.
ALSO HOW WOULD I KNW IF I WIRED UP THE PRESSURE SENSOR CORRECTLY?
