i went for a drive today and car worked fine, Came home parked it, shut it off and took the key out and seen that the battery light came on dim and the afc did not shut off. Car still works the same and voltage is good on battery and on altenator when running and all cables, ground points and wiring is good. Is it getting some sort of feed back power from the altenator or something like that. Any help would be great as i searched and found nothing related.
Thanks
Bobby
Thanks
Bobby
