Just wondering if they are both made out of the same material? Also what tools would I need to assemble the regular Aeroquip SS Braided line, I know the socketless line is easy to work with. Pretty much what are the upsides and downsides of both?
lagged said:SS braid lines arent that hard to put together, just watch your fingers!
its all about how you cut the line the first time. the cleaner the cut, the easier it will be to assemble the fitting to the line.
lagged said:summit has it : EAR-991945ERL
the stock washers wont fit if i remember correctly. the earls fitting i linked to comes with a washer.
for the other one you can go to napa and get an o-ring or wrap some teflon tape, not around the threads but around the base of where the fitting meets with the fuel rail to seal it up.
