I think you will always have problems with the larger turbo with the aem true boost. They don't do progressive boost, they only set to one pressure and once its close to being achieved it will start to open the wastegate. I had issues with this like no other on my MBC, then i bought a decent ebc and it worked very well to limit boost before spiking.
Turn the boost controller down to 13 or so and it probably will still spike then in the higher rpm's the engine will flow enough of that air pressure into the rpm's itll feel like its falling flat on its face.
for me its hard to explain what is happening, but thats exactly how my 57 trim was with a junk boost controller, and no offense, but to me the AEM tru boost is not very good. its basically like a mbc that you can control from inside the car.
A larger (ported) wastegate opening could help some, or lex afm and 550cc injectors (which i imagine you already have if you are trying to bump up to 15psi)
