Add Coolant Light Is On.....
G
gen_Rma70
Guest
the "add coolant" light is on and so i added coolant... then i let it run for a couple mins and its still on whats up with this...
shaeff
Kurt is FTMFW x2!!!!
10
Around
the sensor for that light is in the resivour. did you fill the resivour or the radiator? check both. make sure the resivour is full to the proper level, as soon as it reaches the minimum required coolant, the light should turn off immediately.
-shaeff
G
gen_Rma70
Guest
i filled the radiator.... im supposed to fill up the resivior too???
