So yesterday i charged the AC system after replacing the compressor with a new unit and a new reciever. The compressor would not kick on even after reaching 35psi on the low side. I charged the first can in liquid with the car off through the high side. On my second can after i started the car as stated earlier compressor would not kick on and with my crappy can tap that was leaking a tad bit i jumped the compressor manually cycling it on and off as i charged the rest through the low side. After reaching proper charge level via sight glass, and in car temp reading about 41 degrees at the vents i shut everything off and started trouble shooting. I looked at my pressure switches hoping they werent the problem. I jumped the dual pressure and high pressure switch at seperate times and the ac compressor still wouldnt engage. Check the swtiches with a multimeter they are ok. Moved onto the fuse in the kick panel fuse was good replaced it anyways. Then moved onto the clutch relay behind the battery. It checked out good. I came across this thread while searching for tips.
http://www.supramania.com/forums/sh...-conditioner-electrical-troubleshooting/page2
I noticed Jetjocks post on checking the AC amp and CC. I checked for codes, got an OK via the supermoniter. Turn the AC on no change and no code 51. I checked the ambient sensor in front of the car its within spec. Im at a loss of how to move foward now. I removed the CC from the car to test. Are there any other fuses that i should check before moving foward?
Thanks for your time.
