AC compressor removal
JonoTurbo
Going for broke
CT
How in the heck do you remove the AC compressor from the 1j when it's in the car?
I pulled everything off it but it's stuck on a stud going into the engine block. There isn't enough clearance from the frame rail to pull it off the stud. I don't really seem to have enough room to get anything in there to remove the stud either.
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
The stud has a special end on it. You can buy a bit to match that end and it will come right off. As said you may have to remove ps (I had to disconnect the line) and I also had to loosen the sway bar to drop it out from under the car.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i honestly thought the sway bar option was too much work when i was doing it hehe
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
I didn't have to remove the sway bar, just loosened it so I could jiggle it around and remove the ac compressor from the bottom.
It's not that hard, there's just a lot that you have to do.
tlo86
Jul 24, 2005
3,914
Colorado
well my garage floor is freezing right now :biglaugh::biglaugh:
