Hey
I just got my car back form the shop about a month ago and it had a full rebuild will all new bearings, resufaced block, rebuilt head, hks MHG, arps @ 80ft/lbs, three new pistons, honed cylinders, new rings and all that fin stuff. I have about 4000 kms on it and before I got it rebuilt I got a new water pump put on so that was about 6000kms ago.
Anyways onto the problem. Driving on the highway at about 125ish with AC the temp will start to rise. Once I turn it off, it goes back down. Also when I let my foot get carried away and go past the 240km mark..... the temp rises as well. The alternator is whining so I think that needs to be replaced and apparently the tensioner pulley for the AC needs to be replaced.
Just wondering what it could be. I am running stock temp gauge but I also have amn EGT with probe just behing the 02 sensor and it is running 1200F when cruising at 125-130. and when the car is going 240km the temp jumps to 1400F (5000 rpm) but then drops once you let off.
Mods are ARPs @ 80, MHG, Cooleze DP and Blizt Nur spec.
Any comment or suggestions would be very much apprieciated
