abs/pvc chargepipe who has tryed?
Status
Not open for further replies.
themadhatter
760
Vegas
i was thinking of doing some abs charge pipes for a cheap mod and because some of the stock pipes are in bad shape any one on the board tryed this.Howed it turn out for you?
MDCmotorsports
Indy 500
www.MDCmotorsports.com
I did it too, used the grey piping - worked for a small amount of time.
The problem I had with it was heat related. The hoses kept wanting to pop off becaue the piping itself was warping and melting.
Take out of step's advice and go get some muffler shop to bend you up some hard pipes.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
oddd i ran abs and it works great just the bottom ic pipe has to made of meatl and maken groves ont eh piep will fix this or mealt ring
it's cheep and easy and great mock up for an exhuast shop
jdub
Feb 10, 2006
10,730
Valley of the Sun
Now there's the best reason to use PVC...a mock up for getting the real deal welded up!
themadhatter
760
Vegas
lol sinse i have a 2.5 exhaust on the car and its some getto fab creation from the guy i bought the car from i might just hack that up and use it as charge pipes.
supra90turbo
shaeff is FTMFW!
MA, 01440
Eh, probably not a good idea unless you clean out the piping.. they're all carbon coated inside..
PVC works great as long as you take the finished product before you install it, and get some exhaust tubing that has the same OD as the PVC's ID, and press it in the inside of the PVC pipe.
That will make it more stable under heat where the clamps are placed, as it's braced on the inside to protect against collapsing.
I just don't like the look of it.. it's too ghetto.
If you do it right, well, you're not technically doing it "right" using PVC, but if you route it right, you won't see any of the pipe connections and people won't know it's PVC until you tell them.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
i have sean poeple use pvc then bondo over the seam to hind it or some thing cause i dont knwo if bondo will stick to pvc or abs never really tired
he came into my work work for turbo and taped the ic pipe and asked him where he got his piping and he told me
Status
