ABS light headache
supra_669
23
Ontario
Hey guys, my ABS light is driving me crazy. I tried diagnosing in as per the TSRM but no luck the ABS light stays on instead of flashing a code :'( i changed the ABS module also hoping it was that.... and same problem anyone got any ideas before i loose my mind? any help would be appreciated thanks
supra_669
23
Ontario
As soon as i disconnect the check connector by the abs pump the abs light shuts off. i changed the abs computer behind the glove box and re-checked. Same problem anybody got any ideas for me?
Oct 11, 2005
3,816
Thousand Oaks, CA
I'm confused about your symptoms.
I am assuming the ABS light does not turn off in 3 seconds after you turn the ignition on? Is that true?
So procedure is: turn IGN on, remove check connector, wait 4 seconds, light start flashing. Are you following that order exactly?
supra_669
23
Ontario
ye as soon as i disconnect the check connector the abs light shuts off and doesnt flash. it gives me no codes and i replaced the abs module with a know working unit and i have the same problem
supra_669
23
Ontario
the first question??? u mean connecting to the Tc and E1? .... i tried that i cannot get any abs codes out of doing that
dbsupra90
toonar
indiucky
i am by no means an expert on the subject, but the two times i had the same problem it ended up being a hairline crack in the alt fusible link.
on another one of my cars the abs light came on about 2 weeks before the alternator crapped out.
seems the abs system is very voltage sensitive.
supra_669
23
Ontario
when my abs light is on my cruise control and driving lights dont work. So i cant get the car passed inspection with the abs light on and with the driving lights not working. I drove it last summer with a temp permit and the abs light came on after about a month. So i need to get this abs thing behind me in order to drive it this summer but i will check out the ALT fusible link. do you know where its located by chance?
dbsupra90
toonar
indiucky
it is in the main fuse box under the hood. it's a monster 100 amp fuse, listed as "alt" on the fuse cover. it doesn't pull out, you have to unbolt it from the bottom.
interesting about the cruise and driving lights, i'm gonna look at the diagrams.
edit: i also see there is an abs fusible link as well. i'd check that too, altho i don't see how that would effect cruise and lights. still working on that.
supra_669
23
Ontario
i change the alt fusible link and reset the abs codes and the light is still on i also took a look at the abs fuse and it seemed find power on both ends. im starting to pull out my hair with this problem lol
Oct 11, 2005
3,816
Thousand Oaks, CA
When the ABS light is on the cruise control and driving lights do not work? There is not much in common with those three systems except a few very large fusible links that would cause much more to dfail than just those thee items.
I was going to suggest some tests with the actuator since it is also integrated with the ABS warning light circuit, but instead with this new info we need more detail about what doesn't work with the CC and what do you mean by driving lights (headlights, tails, retractors?)?
