ABS in my 03 Camry
Justin
Speakers?
Spokane, Wa
I got stuck on my way home from class today. I got myself unstuck by rocking back and forth, and a shovel.
About half way through rocking back and forth I noticed my ABS and 'Brake' like came on.
I pulled my car into works bay, jacked it up and visually checked all my lines, and plugs. Everything is visually normal. I pulled the negative battery for about 10 minutes and I still have the two warning lights, as well as no ABS.
any one have any suggestions?
Also: could I cause harm by driving the car with this problem, whatever it may be?
Justin
Speakers?
Spokane, Wa
Lino;878772 said:
Check the brake fluid level, and check the fuses.
Fuses (fusible link) is good.
Didn't think about checking brake fluid... i'll do that in a bit.
Brake fluid is good
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
I know you said you checked plugs, but what about the sensors? I don't see how you could hurt anything, it's an ABS car with no ABS
Justin
Speakers?
Spokane, Wa
Well, I didn't run any tests or anything, but I visually inspected them, and they looked just fine.
Justin
Speakers?
Spokane, Wa
Jeff Lange;879368 said:
I would check the ABS codes, it'll give you a much better idea where to look than anyone on here can.
johnathan1;879387 said:
Pull codes.
Man, I sure say that a lot. :\
(Multi-Quote FTW)
I just found out I could do that on a Camry board, it'll get done as soon as I get home from school :)
