ABS help needed
Mr. Y
80 miles away from Kremlin
When I've got my car ('87T) right front speed sensor was missed (and diagnostic prooved that ;-)
Recently I got sensor, installed it, turn ignition - antilock does not go away. Then I tried to read codes (turn ignition on, unplug check connector) - "antilock" light went away and all. It does not blink =(
All fuses are ok.
Any suggestions - what is wrong?
PS: I've noticed that my cruise control does not work too (worked some time ago) - may be these problems are the same?
Racefiend
OH, YEAAHH!
Apr 6, 2005
106
Bay Area, CA
Check the connection of the 15A ecu-ig fuse in your kick panel. I had the exact same problem, where the abs light is on, the cc didn't work, and neither did the tems. I found the receptacle for that fuse was not making contact with the fuse.
