About to 1JZ
BlackMKIII
Hardcore Lurker
Jan 6, 2007
2,134
Norman, Oklahoma
www.facebook.com
Aaron is doing the swap for me, and here's what I've lined up so far:
3" Y-pipe-back exhaust, using the DM downpipe, 3" high flow cat, and RS*R GT-II.
New EXEDY Clutch Kit.
Other than that, the rest will be stock. I'm on a very, very tight budget. The entire swap cost is being accumulated betwen now and mid-November. As of today, the clip is paid for. I'll "probably" have an extra $500-$700 to diddle with other stuff. What do you guys think I should upgrade before I leave DM?
EDIT: I'm sold on the Koyo race radiator. That's now on the list.
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
definitely get new rad either oem works fine too if you're on tight budget, or get upgraded rad if you have extra cash.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i would say replacing all belts is priority. also the rear main seal because its a pain to get to.
if aaron is doing it he will pretty much tell you what you need as i was about to use him for refrence on what you need hehe. but if your on a budget i'd say those are priority.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
I agree, reseal the engine. Those are harder to get to. Radiator can be changed out quite easily IF it needs to be changed
BlackMKIII
Hardcore Lurker
Jan 6, 2007
2,134
Norman, Oklahoma
www.facebook.com
It is. Aaron does all the seals and whatnot. I'm already sold on the raidiator, but if I had that and one more thing, what would you guys suggest?
Edit: And I'll be keeping my CAI. It should fit with the 1JZ inlet pipe location.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
instead of the rsr why not get aaron's custom exhaust with the carbon TI? dunno just an idea. I would probably save the money too.
OneJoeZee
Retired Post Whore
aboard the Argama
BlackMKIII said:
KTHX Joe.
Just for the record, I made 293@12psi with the same basic mods you listed. That's pretty average for a 1J with freed up exhaust.
No boost controller.
You drove kyle's car right? So you know what to expect. Stock twins will keep you happy for a good while.
Yotaholic
110
Nfld.Canada
With 700 bucks I would buy a rad, 2j water pump , thermostat, t-belt and cam /crank seals and yes, you will need a BCC with an open exhaust and y pipe ( 17.9psi at 50*F these engines love the cold nights :aigo: ) . It's nice to get all this done while the engine is out, not a fun job later. COngrats and good luck to you !!!
OneJoeZee
Retired Post Whore
aboard the Argama
I'm assuming he's already being set up with a complete JZA70 clip, right blackmkiii?(what's your name anyway)
No need to change the fan setup.
