About some connectors/sensors?
80er
9
DK
Hey
Im doing a 1jz swap and i found some connectors/sensors im not sure what is
1st behind the big pulley: http://1jz.thor.prohosting.com/dele/Photo-0062.jpg
1st connected here : http://1jz.thor.prohosting.com/dele/Photo-0063.jpg
And about that i need to know where it is "sensoring" (hehe) and how many taps it have on the crank 24 ? less or more(Where the sensor is counting) , because im having megasquid installed, the guy gotta know.
Next connecter is at the cylhead 2 of them
2 placed back: http://1jz.thor.prohosting.com/dele/Photo-0061.jpg
3 placed forward: http://1jz.thor.prohosting.com/dele/Photo-0060.jpg
They look the same
Im not going to do the harness my self. but i was asked to find out about tease connectors/sensors
Sorry my bad english
My project http://beam.to/1jz (English version is coming)
jt2ma71
Impeller Head
Washington State
I cannot view the pictures but from your description, The crank position sensor is the one behind the big pulley and it reads a 12 tooth wheel (at least on the 2jz, but I think this is the same as the 1J) for the reference signal. The two on the cylinder head are for sync signal (cam/valve position in reference to the crank/piston position) and you can use just one of them for your aftermarket ECU. HTH.
