Check this out?
Yes, it is a 5speed stock R154 transmission in the picture, with just a 1JZ bellhousing since I run a 2JZ, but I am going to upgraded the R to a bulletproof gearbox
at the same level as the V160 getrag 6speed manual transmission. Just got a spare one, and it will be my next project to make it handle 1000hp safely!
That's why I named it , the V154 ;-)
What I got in mind to achieve that goal after many years of search and experience is :
-Multi disc clutch kit. It should be triple or quad disk,and pull type. No conversion kits for push to pull type should be used.
-The best short shifter with rubber dampener for the R154 trans.
-Performance transmission mount. Not solid one,and should be matted with motor mounts also.
-MC upgraded kit , plus the Driftmotion 3-4 and 5-reverse shift forks.
-Toyota oem rebuilt kit with new bearings and seals
-Redline MT lubricant
# and maybe take the transmission at the end to a cryogenic procedure , to increase the metal strength of the gearbox...
Let me know about your thoughts on this guys...
Anything that I missed to add ? Or any idea about going the R transmission to the highest level of performance.
